1999 s80 t6 with only 82k starting to show wear
Old Dec 31, 2012 | 11:37 AM
michaelm's Avatar
Default 1999 s80 t6 with only 82k starting to show wear
i purchased a 1999 s80 t6 for my daughter. has 82k miles. we really like the car. thought it was a good deal. starting to see issues....what can i really expect? front strut mounting plates shot, coolant level low warning message appears with full resevior and no temp issue, some sort of minor oil leak which no one can find...i can use some advice and help.
thanks
Old Dec 31, 2012 | 04:36 PM
migbro's Avatar
A fourteen year old car with 82K miles. Less than 6,000 miles a year. Yes yes, I believe that. Yes I do.
Old Jan 1, 2013 | 11:46 AM
michaelm's Avatar
i purchased the car in brooklyn ny in july 2011. now has 89k on it. city people don't drive much. as you can see in 17 months we only put 7k on the car and that was with my using it for work to keep it running. kids in college don't drive it much either.
Old Jan 2, 2013 | 09:55 PM
biw1428's Avatar
For a 13/14 year old car, an awry sensor, suspension work and a small oil leak? That's pretty darn good! Early P2 platform cars (S80 being the earliest) had their quirks. Suspension components wearing out frequently is one of them. If the car is a T6, transmission problems are quite common when you start getting north of 100k, so keep it serviced. Interior wear also starts to show when these cars get old. Overall, they DO NOT like to be neglected. Putting off any sort of preventative maintenance will only cost you more with these. Also, get your timing belt changed if you haven't already. You may only have 90k on the car, but it's still a 13 year old belt keeping your pistons from slamming into your valves.
Old Jan 3, 2013 | 09:06 AM
migbro's Avatar
Originally Posted by biw1428
......but it's still a 13 year old belt keeping your pistons from slamming into your valves.
Actually it's somewhere between 13-1/2 and 14-1/2 years old. 1999 model year cars were built between July, 1998 and June, 1999.
Old Jan 3, 2013 | 09:52 AM
urbino's Avatar
Default mileage
my 2000 v40 has less than 89k.....
Old Jan 6, 2013 | 07:47 AM
michaelm's Avatar
Thank you for the heads up and advise....you are right,the inside is starting to break down including passenger window falling off track....guy at auto glass place told me to just not use it....cost too much to fix... ...do I make the investment getting the oil leak fixed?
Old Jan 6, 2013 | 08:06 AM
You always get leaks fixed, they will only get worse. 6,000 Miles per year in the big city is far worse that 15,000 miles per year in an rural area or for a highway traveler.
Some oil leaks can be put off a little, like a slow cam cover leak. Some people put off leaks like rms but that's a big risk because the seal can pop out and you can loose a lot of oil in a very short amount of time.
I'm not sure why people always focus on mileage anyway, age will cause many things in a car to fail. Rubber, plastic, rusty metals will cause just as much problems as high miles. When my 740 GLE had over 400,000 miles on it, it was in better shape than a most cars with less than 200,000 on them.
ilyasxkhan
Sep 17, 2021 05:58 AM
kawish1659
1998-2000 model year V70
Feb 19, 2015 02:46 AM
7antera
Jun 2, 2008 08:00 AM
brobertsn
Aug 12, 2007 06:42 AM
