1999 Volvo S80 RR door won't open
Old Mar 16, 2015 | 12:27 PM
Wayne in VA's Avatar
Default 1999 Volvo S80 RR door won't open
I have worked all the codes, fixed everything on this car except RR door won't open from the inside or the outside (did when I first bought it).
This weekend I replaced the trunk latch. Works perfect. Nice to have a trunk that opens with FOB and by pressing the latch.
My local pick-and-pull salvage yard, has had numerous S80s, and I have the already pulled the RR door lock assembly. Guess, I pull the door card from the inside reach in and manually open. Then replace latch.
Any suggestions would be appreciated. I am always interested in a better way.
Wayne
Old Mar 20, 2015 | 09:45 AM
Default How to get a door Open when inside and outside handles do not work
So, I pull the door upholstery trim and CARD from the inside reach in and manually open?
Then replace latch?
Old Mar 27, 2015 | 03:28 PM
Husker1's Avatar
Any luck on your door issue? I had a similar problem on my 99 S80 but it was related to the master window switch/lock that my mechanic fixed.
I'll ask him what it was and post back.
Old Apr 13, 2015 | 01:00 PM
Cool Door has not been a Priortity
Door still is not a priority. 99% of the time, its just me in the car, so far no one has rode in the back seat. I am a busy guy, have the part on hand to fix it. Just as of now it is not a priority.
My master door switch open and unlocks the door. I have an extra master door switch that does the same. My problem, is you cannot open the door using the inside handle or exterior handle. The lock button goes up and down.
While at the wrecking yard, I picked up a new lock assy, and retainers for the inside door card. Putting them on, well there is a laundry list of stuff ahead of it. Like staying in shape. Working on my farm and farm equipment, feeding cows, a full-time job, that puts me on the road traveling.
I will get to it. Someday. its on the list.
Wayne
Kim_in_Alaska
Jul 3, 2021 12:13 PM
Coffey
Jul 24, 2016 09:34 PM
FujativeOCR
Feb 11, 2011 11:04 AM
petes99xc
Mar 22, 2007 11:22 PM
volvodan
Dec 18, 2006 09:16 PM
