2000 S80 N/A Indication lights on
Old Sep 12, 2008 | 10:38 PM
S_Joly's Avatar
Default 2000 S80 N/A Indication lights on
Ok, took delvery of my "new" 2000 S80 2.9
Some issues right off the bat.
1.) ABS, traction control, and other lights on
2.) When I Hit bumps, the "no oil pressure safely pull over asap" light comes on, first time I did, shut off the car restarted with hood up there was no indication of low/no oil pressure (ticking, grinding, rattles) at all. Also turns on when cornering.
3.) I am already aware it needs the abs modual needs to be replaced/rebuilt, but will it cause all these problems?
Other than that the car runs and drives great. Also found the orig. window sticker $38,775 WOW, not suprised really
The color Name is Moondust metallic.
It also has a security package "Homelink Security Pkg" (What does it do?) And 16" T6 wheels (on sticker)
I will post some pics when I get a chance.
Old Sep 12, 2008 | 10:42 PM
Default RE: 2000 S80 N/A Indication lights on
The ABS module will cause everything but the oil light.
Check the oil level and see if it looks like there is sludge in the top of the engine. If not it might need oil pan o-rings.
Old Sep 12, 2008 | 10:48 PM
S_Joly's Avatar
o rings go where?
oil clean no indication of sludge.
Old Sep 12, 2008 | 10:49 PM
S_Joly's Avatar
Also any idea what the homelink does, or how to work it?
Old Sep 13, 2008 | 08:08 AM
The oil pan o-rings go between the oil pan and the block.
Homelink is a garage door setup built into the car. You can program a garage door opener to it then one use the button on the visior.
Old Sep 13, 2008 | 11:16 AM
Crito's Avatar
Banned
Sounds like mine when I got it last week. 30 AMP fuse in the engine compartment fixed my ABS problem.
Old Sep 13, 2008 | 12:41 PM
S_Joly's Avatar
The oil light really mean no oil pressure? I drove the car today and started hearing a rattle/knock. May need a motor by the sound. How much a good used run? Im in GA.
S_Joly's Avatar
BTW 1st line a joke
Old Sep 13, 2008 | 12:47 PM
If it was a tapping then it might have just been the lifter semi dry on oil.
If it was a skocking then the motor might be done.
Call local places. Not sure how avalible the motors are that will set the price.
Old Sep 13, 2008 | 12:58 PM
S_Joly's Avatar
Whenever I start the car, nice and quiet, rev it a bit, rattles, it does sound like the noise is in the head area, lifter? Dunno for sure.
Old Sep 13, 2008 | 02:19 PM
Maybe the lifters. I would try replacing the oil pan o-rings first.
Old Sep 13, 2008 | 03:36 PM
S_Joly's Avatar
1-10,difficulty no lift home mechanic? Do i haveto go to volvo for parts?
Old Sep 13, 2008 | 04:11 PM
I would buy the parts from volvo.
Check out link for kind of a walkthrough.
https://volvoforums.com/m_6168/tm.htm
Old Sep 13, 2008 | 08:47 PM
S_Joly's Avatar
Gota 2nd opinion on the noises, looking like a rod bearing, I checked all 4 part sites with no luck. I am wondering if this is going to be a dealer only item?
Old Sep 13, 2008 | 09:03 PM
From a shop?
Old Sep 13, 2008 | 11:20 PM
S_Joly's Avatar
Friend with a shop helped. Noise becomes much more noticable while engine is accelerating, less when revs are dropping. Took a closer look at the head through oil fill, there is a lot of caked on crap, even on the camwhere the lifters contact eachother.
Old Sep 14, 2008 | 07:23 AM
  #17
I will tell you this if it is the rod bearings then the motor has been driving like that for a long time. I have seen many of these motors run on only 1 quart of oil many times without major damage to the bearings.
Old Sep 14, 2008 | 09:30 AM
  #18
vegasjetskier's Avatar
You can try this stuff to clean out the sludge. If it's your lifters it might clean them up and get rid of the noise. http://www.auto-rx.com/
Old Sep 14, 2008 | 09:51 AM
  #19
But usually the pick up tube gets clogged as well when there is sludge in there.
Old Sep 14, 2008 | 11:57 AM
  #20
S_Joly's Avatar
would that cause no oil pressure?
