2000 S80 N/A Indication lights on
Old 09-14-2008, 09:19 PM
S_Joly's Avatar
Default RE: 2000 S80 N/A Indication lights on
I got some "gunk" flush, what cup or tool you all use to take the filter cartridge cover off? I tried a band style and pliers style, no luck.
  #22
Old 09-14-2008, 09:59 PM
vegasjetskier's Avatar
ORIGINAL: S_Joly
I use a small band-style wrench on mine, but if you can't find one that will fit you can get the right tool here: http://www.eeuroparts.com/Main/PartDetail.aspx?id=A261
  #23
Old 09-14-2008, 11:59 PM
S_Joly's Avatar
Thanks, the one i was useig was chain style, but ill pick up a solid one, and if that doesnt work, ill get one of the cup style
  #24
Old 09-15-2008, 04:52 PM
Yes it will. Also the o-rings being bad will. The o-rings seal the pan to the motor to bring the oil to the top of the motor. Also there is a cross pipe in the pan bringing the oil from the filter to the oil cooler.
  #25
Old 09-15-2008, 06:12 PM
S_Joly's Avatar
Ahh, hw much does it usually cost for a shop to do it? The previous owner is probibly going to assist with the cost, Thank you all for continued help.
  #26
Old 09-15-2008, 06:18 PM
Depending on local areas it would be best to call shops and get pricing.
I would say about 5 hours labor plus parts.
  #27
Old 09-15-2008, 09:47 PM
S_Joly's Avatar
cool, appreciate it.
s80pos
10-17-2014 08:56 AM
Billc
11-25-2007 09:22 AM
ryhaddi
11-20-2007 04:08 PM
TheVolvoMan
01-08-2007 09:22 PM
Quick Reply: 2000 S80 N/A Indication lights on
