2000 s80 sunroof questions
Old Sep 16, 2012 | 05:11 PM
barons77's Avatar
Default 2000 s80 sunroof questions
the sunroof went out in my s80 a couple of months ago. It is not driven often so i didnt worry about it. I went in the car today after not being in it for about 2 weeks and the passenger side floor was drenched in water. After doing some research i figured it was the sunroof drain clogging up. my problem is that while i took down the headliner and found the drain, I cant find where it goes to. While the headliner was down i decided to take out the sunroof motor and relay and i was also wondering if there was any way to test the motor while not hooked up to the car. thanks for your input
Old Sep 17, 2012 | 10:16 AM
jriggs87's Avatar
Find the drain and spray compressed air through it to unclog. A new motor probably wouldn't cost too much. Ebay I think starts at 50bucks. Or go to salvage yard most places charge 10 for a motor, but you take a risk not working. Can't help you on testing it, maybe try replacing relay to see if that's the problem
NightTrain
Jun 2, 2013 04:25 PM
Phil 850
Jul 25, 2012 10:01 PM
90240DLGA
Oct 5, 2009 10:35 PM
mjwaterma
Jun 19, 2009 07:15 PM
JoeTest
May 10, 2007 06:36 AM
