2000 S80 timing belt replacement
Old Jan 13, 2009 | 05:12 PM
jameswr's Avatar
Default 2000 S80 timing belt replacement
My 2000 S80 is well past 105K. I havent disassembled yet, but should I plan to replace the water pump preventively, even if it looks good? What about thermostat? I plan to replace the tensioner and idler. I see parts listed for the tensioner and tensioner pulley- do I replace both? Thanks, jwr
Old Jan 13, 2009 | 05:18 PM
Default RE: 2000 S80 timing belt replacement
You can do the water pump if you want.
The tensioner should be the manual on your car.It should be part# 30638277 I believe. Sorry I forget the idler one though. But the idler is only a pulley no brackets or anything.
75ohm
Mar 13, 2017 10:37 AM
eugenc
Aug 21, 2009 10:48 AM
B18Eric
Jan 23, 2009 06:48 PM
stevo77
Jan 20, 2008 03:59 PM
