2000 S80 Wheel Spinning Problem
Old Nov 1, 2010 | 10:27 AM
Charlieukfan85's Avatar
Default 2000 S80 Wheel Spinning Problem
I have a 2000 Volvo S80 T2.9 and I recently had to replace 4 tires because I was loosing tread in uncommon places, like on the outside of the rear tires and the middle of the front tires. I had the rear wheel bearings replaced as well because loud noise and vibration in the rear tires.
I bought 4 used to tires and had to upgrade to 225/60/16 tires because that was the only tires the dealership had used (I wanted 4 cheap tires). As soon as I picked the car up and drove off the lot and started to accelerate the tire slipping light came on in my dash and I was pushing the accelerator and the car was not accelerating. The past couple days this has been occasionally happening when I am going about 15-30 mph. I let off the gas and kind of tapped it till it started going again. This does not happen all the time usually just within the first 10 minutes of driving, then it will not happen again. When it does happen the RPM's do not rev up like the car is in neutral, the RPM's stay normal and I just coast until the tires start accelerating again. Any thoughts what this could be? Are the tires too big in the front?
Old Nov 2, 2010 | 05:49 PM
jlewisinsyr's Avatar
Sounds like the sensor or the sensor ring is damaged/broken.
Old Nov 3, 2010 | 08:10 AM
Which sensor or senors do you think it may be? And do you know where they are located? If located in a location I can easily get to I would like to test the sensor. Thanks for the help!
Old Nov 3, 2010 | 11:54 AM
Is this a Speed Sensor problem? If so where is the sensor located? Lately, the problem just occurs when I leave in the morning for work and I get up to about 30mph and the STC light comes on and the accelerator will not speed the car up. So I let off the gas until the light goes off and then it will start accelerating again and the problem usually doesn't occur for the rest of the day.
Old Nov 8, 2010 | 10:49 PM
NoLifeTilBoost's Avatar
If you hold the STC button down to turn if off does it stop the problem? Theres a speed sensor on each of the four wheels. In theory if you had a big circumference difference between front and rear tires it would will set the STC off, but I have no idea what the % would need to be.
rationull
Jan 25, 2022 03:12 PM
yoyoman
Jan 10, 2011 06:53 PM
AlanS
Jan 5, 2011 02:41 PM
A_aron
Jul 23, 2009 07:21 PM
danerrr808
Jan 27, 2008 09:08 PM
