2002 S80 T6 Alternator Plastic Covered NUT
Old Jun 18, 2011 | 10:47 AM
django1's Avatar
Default 2002 S80 T6 Alternator Plastic Covered NUT
I am trying to replace the voltage regulator on our 2002 S80 T6 and ran into problems taking this plastic/rubber covered NUT(attached similar pic found on internet). The plastic/rubber is almost totally torn up on mine, and it appears that the nut it covers is not HEX but round shaped. This is NOT the B+ terminal. The B+ terminal had a plastic/rubber boot that is removable and then a regular hex nut that holds the RED B+ heavy wire.
Does anybody know the function of this plastic covered nut? Why is it covered with plastic (or rubber), and why a round instead of HEX nut embedded in it? Is this some kind of anti-TAMPER device for warranty purposes?(i.e. warranty void if this plastic covered nut is removed).
Is it meant to be removed using a special tool (from Bosch maybe?)?
Thanks.
Attached Thumbnails 2002 S80 T6 Alternator Plastic Covered NUT-volvos80boschalternatornut.jpg
Old Jun 18, 2011 | 01:50 PM
ed7's Avatar
ed7
The plastic surrounds the hex, it doesn't hold the plastic down.
Ed
Old Jun 18, 2011 | 09:17 PM
django1's Avatar
Default Plastic covered NUT
Ed,
Thanks for the quick response.
I think it will look like this (new attached pic) once I am able to remove the plastic/rubber covered nut. It looks like a round metal nut embedded in plastic.
I still haven't figured out why they used such a part.
Attached Thumbnails 2002 S80 T6 Alternator Plastic Covered NUT-looks_like_this.jpg
Old Jun 20, 2011 | 05:24 PM
django1's Avatar
Default Anybody?
Has anybody worked on a volvo or bosch alternator that has this plastic covered nut? Please read the start of thread. Maybe you know the answer. TNX
FernBchJeep
May 26, 2013 08:47 PM
alphaville
May 5, 2009 07:26 PM
Saleen9090
Apr 18, 2009 11:25 PM
m1964
Mar 20, 2009 10:35 AM
jerrym
Dec 12, 2007 08:58 AM
