2004 S80 Camshaft/crankshaft position sensor
Old Aug 2, 2022 | 06:24 AM
Domaim's Avatar
Default 2004 S80 Camshaft/crankshaft position sensor
Hello, does anyone know if the camshaft position sensor and crankshaft position sensors are hard wired? When I do a replacement parts search, It shows the sensor with a plug end. When I follow the wires on the car it doesn't seem to have a plug end.
Thanks, Domaim
Old Aug 2, 2022 | 09:16 AM
Replacement sensor pictures are correct. Why do you ask? Are you attempting to replace sensors because you have a code? Very rarely do those sensors have a problem. The most common problem it the cam timing is incorrect - and you will get cam or crank sensor codes because of that.
Codes are stored because a control unit does not like the signal from a part - codes are not necessarily stored because a part is bad.
Old Aug 2, 2022 | 11:19 AM
Free lift to the S80 board. "forum issues" board is for issues with the forum :-)
gbri
Jun 10, 2019 07:13 AM
tryingbe
Apr 2, 2018 08:15 AM
habbyguy
Nov 10, 2014 07:01 PM
jdmser
Sep 27, 2010 06:26 AM
