2004 Volvo S80 Cranks but won't start
Old Jan 3, 2020 | 02:25 PM
warriors80's Avatar
Default 2004 Volvo S80 Cranks but won't start
Hello Forum,
I have had this problem for awhile and I am at a loss. The car will crank but will not start, it will briefly start on spray. I have replaced cam and crank sensors, coil packs, plugs, and even had a new ECM programmed and installed. My mechanic thought the engine is bad so we replaced it with a working and tested engine. It has spark, fuel and compression but we are at loss of things to eliminate. I swapped out the antenna ring for another one and still nothing. We swapped out the fuel pump relay not to mention others and checked fuses. I am I missing something really simple? Any suggestions or advice would be greatly appreciated. Thanks in advance
Old Jan 3, 2020 | 03:06 PM
donf's Avatar
Let me get this straight, your mechanic replaced the cam and crank sensors, coil packs, plugs, and had a new ECM programmed and installed. Then he decided the engine was "bad". (What does that mean anyway?) and installed another engine.
And you still have faith in this guy? Yes you are missing something really simple, the first thing I would check now is the phone book ior another mechanic.
Old Jan 3, 2020 | 03:52 PM
warriors80's Avatar
Pretty much, LOL Either selling it to a junkyard or hopefully can figure it out
Lyndon Cander
Jul 29, 2018 07:07 PM
vwynn
Dec 29, 2017 01:02 AM
volvoFETT
Jan 5, 2017 07:26 PM
venkman
Dec 11, 2015 08:35 PM
one320fc
May 24, 2013 10:05 PM
