2008 s80 4.4l
Old Jun 24, 2018 | 04:07 PM
nb2008s80's Avatar
Default 2008 s80 4.4l
My exhaust heat risers are noisy and would like them fixed so where exactly are they located?
Thanks in advance.
Old Jun 24, 2018 | 07:02 PM
tony1963's Avatar
Heat risers?
https://www.rockauto.com/en/moreinfo...323863&jsn=433
Those went out of production on vehicles 30 years ago.
Old Jun 24, 2018 | 08:35 PM
nb2008s80's Avatar
Default heat risers
Thanks but I know what they look like but don't know where they are located on the exhaust system. Are they on the manifold or where?
Old Jun 24, 2018 | 10:23 PM
nb2008s80's Avatar
Default heat risers
Found the answer. on manifold
Old Jun 25, 2018 | 03:53 PM
tony1963's Avatar
I think that there is a misunderstanding. Heat risers were used on carbureted engines to assist in vaporizing the fuel that would condense on the cold cast iron manifold. With the advent of fuel injection, those went away as unnecessary.
I'm curious if you are talking about the heat shields on the manifold or something else.
Old Jun 25, 2018 | 06:24 PM
nb2008s80's Avatar
Default heat risers
the 2008 s80 4.4l is normally aspirated so I meant heat risers
Old Jun 26, 2018 | 07:20 PM
thommykent's Avatar
Never seen heat risers on fuel injected engines either. I don`t see anything looking like a heat riser in the exhaust system diagram
https://www.tascaparts.com/auto-part...-manifold-scat
Old Jun 26, 2018 | 07:50 PM
ES6T's Avatar
There are no heat risers.
Old Jun 27, 2018 | 01:34 PM
tony1963's Avatar
If the OP wants to believe that it has heat risers, then let it be.
Old Jun 27, 2018 | 02:44 PM
nb2008s80's Avatar
Default heat risers
This OP just called a dealer who confirmed no heat risers. it sure sounds like heat risers so he said the mufflers are doubled wall and one mnight be rusted and making the noise. I only hear if stopped at a light idling so if it's not heat risers any suggestions? Thanks so far for input.
Old Jun 27, 2018 | 04:46 PM
tony1963's Avatar
This entire thread could have been more helpful to you if you simply asked about a noise at idle.
I tried to tell you that those things went out of production over 30 years ago.
Check to see if any of the heat shields are rattling.
Old Jun 27, 2018 | 06:20 PM
nb2008s80's Avatar
Default heat risers
I obviously still learning anout this car so help is appreciated. I will have a.mrchanic put it up check shields
dzfamily
Oct 26, 2016 01:31 PM
S80Savage
Nov 8, 2015 10:16 AM
RDB623
Sep 25, 2014 07:43 PM
23Bar1
Jan 5, 2014 05:55 PM
JVervekken
Nov 7, 2009 03:38 AM
