View Poll Results: Where to start?
PCV replacement
0%
Wiring, circuits, and fuses
0%
Time to move on
0%
Voters: 0. You may not vote on this poll
2011 Volvo S80 3.2 L6 (B6324S4) Error Codes galore!!
Old Sep 21, 2023 | 08:31 AM
MJDalton's Avatar
Default 2011 Volvo S80 3.2 L6 (B6324S4) Error Codes galore!!
10 months ago. Millie (my Volvo) got a new battery plugs and wires. Recently she shut off while driving. Had her towed to a garage. They said it was the alternator. Had a new one put in. A week later all of a sudden she didn't have any more power. I was told she likely needed the PCV replaced a gasket and an O2 sensor. However, when I look up all of the codes, the most common theme I see is circuit problems fuses and defective wiring. I can't afford to get ripped off and just keep throwing money I don't have at a problem no one seems to put the big picture together & there isn't a Volvo dealership in the area I live in.
Here's the list of codes populated
P0303-00
P0420-00
P0700-00
P0562-00
P1799-00
U04-15-00
P0744-68
U3003-16
B-10f4-15
B1D38-19
U0010-88
C2007-13
C2008 -13
U0 422-68
U3000-00
B1-05a-71
B10 b9-12
B10 b9-13
B118E-00
B. 1190-00
B1A98-87
U2013-24 and U 2101-00
B118F, b1191, 989887H \10131591 u0010, u0140, e00224H/ 14680612 you 2101
B1b69-16, u0151-00, u0156-00, u0422-68
u 3003-16
P0420, p0700, p0562
Old Sep 25, 2023 | 08:21 AM
proanglerh1's Avatar
Post hope this helps
Because most of these errors are electrical, i would confirm your battery is getting charged by your alternator. They could be false errors due to lack of voltage. A charged battery should show over 12 volts, and a alternator will bring that up to around 14.0 volts. Hopefully you have a voltmeter to check this. If not, you can get them fairly cheap and its always good to have one around the house.
Old Sep 25, 2023 | 09:51 AM
Erase the codes, drive the car and recheck codes.
What codes come back? If any address the ones that come back first.
Did your new alternator come with a new overrun pulley? Or was the old pulley reused?
(and what "wires" were replaced?)
Old Sep 29, 2023 | 12:58 AM
Deb C's Avatar
Hi
Did you end up getting to the bottom of this issue?
Deb
Trendsetter27
Oct 17, 2018 12:02 PM
COLKLENK
Jul 5, 2017 10:10 PM
s80t62.9
Dec 7, 2013 06:42 AM
Volvo Forums Editor
Nov 28, 2011 01:25 PM
wlfire55
Oct 29, 2009 09:27 PM
