2014 S80 Wiring diagram. (AC)
Old Aug 26, 2023 | 05:10 AM
joerlund's Avatar
Default 2014 S80 Wiring diagram. (AC)
Hi.
I have problems with my AC/Clima. Not turning on.
Clutch - Do not engage.
A quick test with12 volt+ directly to clutch - still not working.(That is one issue)
A manuel test of the relay = OK
Relay in fuse box = Not working....
The fuse i OK
The main-wire from fuse box is yellow/Green but this wire is not present at the AC Compressor.
Present wire at compressor is White/Brown.
What am I missing?
I so badly need a diagram of this system. Hope you can help.
BR.
Jørgensen
Denmark.
Old Aug 26, 2023 | 11:19 AM
Here's a wiring diagram for a 4 cyl. (don't know what engine you have) Many things can stop the compressor from turning on. Outside air temp, evap air temp, engine temp are just three of the parameters that can control ac relay/clutch operation. Note the ECM grounds the relay to energize the clutch. You might start with a compatible scan tool that can talk to all the control units in the car.
Old Aug 26, 2023 | 11:55 AM
joerlund's Avatar
Thanks... Really appreciated.
More to do tomorrow!
Diesel 4-Cyl. 181 Hk. / 133 kW. D4204T5
Aut. AWTG-81 SC
alex1366
Aug 10, 2021 01:05 PM
rspi
Jun 17, 2013 01:16 PM
parrym
Jun 24, 2011 09:38 AM
avguy
Feb 17, 2011 10:26 PM
