View Poll Results: Any ideas?
Fuel issue
100.00%
Computer issue
0%
Injectors
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
99 s80 2.9 won’t start
Old Mar 15, 2024 | 02:26 PM
Philencabinets's Avatar
Default 99 s80 2.9 won’t start
1999 s80 2.9 won’t start, has fuel has spark and it will crank but won’t start, the rpm will spike high when trying to start and before when it would start when I tried to start it and wouldn’t turn over so the engine would be off but the starter would click like it does when you try and start it when it’s running but it’d do this with engine not running but then it’d start next try. The injectors pulse was not the same across all 6 when I pulled them out. Any ideas thanks!
Old Apr 13, 2024 | 10:15 PM
Niklas11Braun's Avatar
I'd advise looking into the fuel system, like the fuel pump, filter, and pressure regulator. There might be a blockage or pressure problem causing the uneven fuel supply.
Also, check the timing parts, such as the belt or chain, for wear or alignment issues.
And I’d check for anything that maybe blocking the air intake system.
Have you checked for error codes or run a diagnostic scan yet?
barelyrunning
May 16, 2023 11:39 AM
jonc123
Feb 17, 2010 03:59 PM
rj131979
May 7, 2008 07:33 PM
spike1962
Apr 25, 2008 06:56 PM
kandio
May 11, 2007 11:50 PM
