2007 S80 Trunk light
Old Apr 7, 2024 | 05:47 PM
NH_Don's Avatar
Default 2007 S80 Trunk light
Trunk light not work when trunk opened, but brake lights come on when opened. Bulbs good.
Fix anyone?
Old Apr 13, 2024 | 09:59 PM
Niklas11Braun's Avatar
Check the wires in your trunk, especially where they bend or go into the trunk lid. They can get damaged from opening and closing the trunk a lot.
Also, test the trunk
switch and make sure it’s getting enough power and engaging correctly when the trunk is opened.
Plus, I’d check the trunk light relay and fuse.
Old Apr 14, 2024 | 03:44 PM
NH_Don's Avatar
Default s80 Trunk lighting
Thanks Niklas for reply. I think switch ok as running light illuminate when trunk opened.
I can find no info on relays nor any indication from sources on fuse location.
Will look at all fuses in trunk, but hoping for any other experience in troubleshooting.
I think cable is OK but where is switch? Is it not the trunk lid lock?
Dilovan
Jun 18, 2021 08:21 AM
hundolfini
May 9, 2016 11:10 AM
Tropicalcats
Oct 14, 2014 01:59 AM
jmp29
Jul 17, 2009 03:50 AM
weston97glt
Jun 25, 2009 06:49 PM
