ABS light still on
Old Mar 10, 2008 | 07:52 PM
mkelly85's Avatar
Default ABS light still on
I just installed a rebuilt ABS module from BBA today on a 2001 S80, and the ABS, check engine and traction lights are still on, even after driving it. Aren't these supposed to go away by themselves? The check engine light code was pulled before replacing and read P1550.
Old Mar 10, 2008 | 09:33 PM
Default RE: ABS light still on
If BBA didn't clear the codes you will need to have them cleared.
Old Mar 10, 2008 | 10:16 PM
mkelly85's Avatar
Alright, but after a while, it's going to be cheaper for me to get a scanner if I have this problem with almost every Volvo I come across.
Old Mar 16, 2008 | 02:30 AM
mkelly85's Avatar
After having the mechanic look at the suspension again, he discovered the wire leading to the wheel sensor was severed. Fixed it and the ABS light, STC light and check engine light all went away. I wonder if I needed that ABS module afterall.
Old Mar 16, 2008 | 07:14 AM
If you didn't at that time you would have soon.
Besides when they rebuild them they make them alot better than factory.
Old Mar 16, 2008 | 02:12 PM
mkelly85's Avatar
I think someone has worked on it before, one of the e-5 screws were missing. The module I received was glued together with two gaping holes I had to plug up myself before installing to keep moisture or dirt from entering. So is it a lot better than factory? I don't know, but the car is for resale anyway. I would hate to have installed it the way it was shipped to me and sell the car to someone like that.
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
Alyan
Dec 14, 2010 04:42 PM
bumere46
Jun 26, 2009 09:21 PM
cioara
Apr 8, 2008 10:01 PM
