Air conditioner
2011 Volvo s80......husband changed the relay switch, compressor not kicking on.
Have you checked to make sure there is 12 volts getting to the compressor clutch? (by unplugging the compressor and testing the voltage at the connector) If there is power and the clutch is not turning - I would inspect the compressor clutch. If the clutch is actually spinning the compressor and the big pipe on the compressor does not get cold (careful the small pipe can get very hot) the next step would be to check ac pressures, and scan the car for any self diagnostic codes. With a good scanner you can verify all sorts of parameters - for instance if the ac evap temp sensor thinks the ac is too cold - the ac clutch won't turn on. I have replaced a few bad ones of those. Other incorrect temp/pressure values can do the same - outside temp too cold, or ac pressures too low or high. You would want to verify all sensors are working correctly and make sure the system is fully charged (easiest sometimes to simply evacuate and recharge with the correct volume) - before guessing on a ~$150 part +labor+freon.
Here's a picture of a sample displacement valve
Same problem here. My issue is the climate control module mounted on the dash center console which needs replaced. Part was 800$ US last I checked and dealer may need to program a code into it for it to work. Part is easy to install, but expensive if needs programmed. I have chosen not to replace mine as my defroster and floor air work well enough. Good luck to you.
