Help! No air out of vents
Old Jun 9, 2006 | 03:36 AM
ozarkboater's Avatar
Default Help! No air out of vents
On a long trip tonight the air stopped flowing fron the vents. The fan sonds like it is working at full blast to cool our '06 S80 but I cannot get any air out of any vents. I have tried selecting the defrost, the upper, mid, lower and auto settings with all the same results. It seems like a damper is stuck or somthing is stopping the air flow.
Old Jun 9, 2006 | 05:00 PM
studd34000's Avatar
Default RE: Help! No air out of vents
you could try checking your cabin filter
Old Jun 9, 2006 | 09:55 PM
Are you still under warranty?
It sounds like the evaperator is freezing up.
Old Jun 30, 2006 | 02:18 AM
It did it again tonight. It seems that there is cold air but it is not blowing out of the vents. The last time this happened, the air did blow fine the next morning (after the car sat overnight).
If the evaporator is freezing, is there a way to prevent this?
Thanks
Old Jul 1, 2006 | 09:24 AM
To stop it from freezing you will need to replace the Evap. temp sensor.
It is pretty easy to replace. I think the sensor is only like $30.00 or so.
Old Jul 5, 2006 | 09:17 AM
Thanks for the help, I will take it to the dealer.
cutypie
Oct 26, 2011 05:29 PM
elbert
Oct 18, 2011 10:54 AM
ryan29121
Oct 29, 2010 04:32 PM
skateandneverdie
Sep 10, 2010 01:19 AM
copurnikus
Oct 18, 2005 04:54 PM
