Bad ignition coils
Old Mar 13, 2012 | 03:40 PM
murp0234's Avatar
Default Bad ignition coils
I drive a 2000 Volvo S80, 6-cylinder. I learned that I have 3 bad ignition coils that need replacing at about $700-800 for parts & labor. I'm trying to avoid putting any more money into this car that I may soon replace.
What happens if I don't replace the ignition coils? I realize that the car's performance/accelleration is sluggish and I'm not getting the best gas mileage, but am I at risk of causing more serious engine damage?
Thanks
Old Mar 13, 2012 | 06:38 PM
Lifesgoodhere's Avatar
depends on if you have a constant miss. Have you made sure its not the wiring. I accidentally pinched a wire after doing a timing belt on a V40 today. thought it was a coil. As soon as I took the plastic covers off miss went away (repaired wire it and was ready to go)
Yes it seems coils drop like flys. Happened to me more than once. It takes only about 30 minutes -- hour and a half tops if you are taking your time and doing it on your lunch break to replace all coils. That price quote is high.
used coils run about $75 each. Find a junk yard.
its never a good idea to run a car that has a noticeable miss, or when it throws check engine light.
Old Mar 13, 2012 | 08:44 PM
537playing's Avatar
This is an easy DIY job. The coils should cost you $50.00 each. Shp around and save yourself $550
Old Mar 16, 2012 | 10:04 AM
travismail's Avatar
I find it hard to believe that 3 went all at the same time but if you are planning on dumping the car just buy some at a salvage yard for cheap.
Old Mar 16, 2012 | 09:12 PM
check ground wires. attached with 8mm size hex bolts there are two of them.
Old Mar 17, 2012 | 03:20 AM
poopbunny's Avatar
Step by step tutorial here
http://www.matthewsvolvosite.com/for...p?f=11&t=17431
Coils here
Ignition Coil with 103mm Insulator Boot
ipd HD Ignition Coil with 103mm Insulator Boot
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
jag2010
May 14, 2007 07:16 AM
Ham
Jan 16, 2007 10:00 PM
AT Girl
Aug 12, 2005 09:49 PM
