??bad steering wheel module??
Old Oct 26, 2008 | 07:47 PM
NasS80Tbo's Avatar
Default ??bad steering wheel module??
Hey all, Ive been scanning the posts as I always do for things that may be wrong with my 2000 s80. After doing some reading I think I have a bad steering wheel module. Currently have no use of cruise control or radio control from steering wheel. Blinkers stopped working, no high beams, wipers operate on one speed, and my service messages seem to be frozen on ABS service. The horn works, if that changes anything.
This all came about suddenly when making a 140 mile travel 2 weeks ago. Before this I had the ABS/STC message, and no cruise/radio control. During that trip I realized that the radio controllers all of a sudden started working. So i played around and found that cruise control and my messages were working as well. After a half an hour the message screen froze, I couldnt use my blinkers and all of the other stuff.....
I heard a few things:
1. Have the steering module reset (dealer or reg shop) cost ?
2. Software upgrade (assuming must be dealer) => cost ?
3. Buy a new module => cost ?
Also my left low beam went out at the same time. Should I try replacing the bulb or is this part of the whole steering wheel module thing? if that is indeed what I am dealing with.
Thanks in advance for what my options and estimated prices might be
Old Oct 26, 2008 | 08:28 PM
rotgut's Avatar
Default RE: ??bad steering wheel module??
as far as the steering wheel module, locate the fuse for it, pull it out for a about 5 or ten mins. then plug it back in, see if it helps, rotgut
Old Oct 27, 2008 | 07:52 AM
Replace the bulb.
Not sure about the software that is all new to me and it may work.
Old Oct 27, 2008 | 01:27 PM
NasS80Tbo's Avatar
where exactly is the SWM loctaed? And is it as easy as dissconecting for 5 minutes then reconnecting?
Thanks
Old Oct 27, 2008 | 01:30 PM
Pull the fuse for it. The steering wheel module is burried behind the steering wheel.
Old Oct 27, 2008 | 05:19 PM
NasS80Tbo's Avatar
I did change the bulb for the left low beam and it does work... it must have been a coincidence with everything else going on. I'll have a buddy locate the fuse and pull it. I'll let you know what happens.
And just in case what's the estimated cost for a new module???
Thanks
Old Oct 27, 2008 | 05:23 PM
Forget exact price but pretty expensive.
trainlover
Mar 16, 2014 08:48 AM
benett0n
May 23, 2013 10:19 AM
2002v70
Oct 17, 2009 06:31 PM
Tschadt
Jun 5, 2008 10:05 PM
