ball joint HELP needed
Old May 20, 2006 | 11:52 PM
med01e's Avatar
Default ball joint HELP needed
I need help with replacing a ball joint on a S80. I am in the middle of the job and can not get the new ball joint reattached to the control arm. I got the everythiong talken apart and the new ball joint bolted into the hub.
When I try to swing the hub over the control arm - I can't get it lined up. What am I doing wrong? Is there something I need to do differently?
Any help would be appreciated.
Old May 21, 2006 | 12:51 AM
Default RE: ball joint HELP needed
Good luck the Balljoint is actually pressed into the Hub.
There is a special tool that slides over the balljoint then to hit it in with a Hammer.
You install the Balljoint in the the Hub the into the control arm.
Old May 21, 2006 | 11:52 AM
med01e's Avatar
Thanks, but I was able to get the new ball joint into the hub. What I can't get is the hub attached to the control arm. I doesn't want to swing back. Do I need to disconnect the strut or is there some other step that I am missing. Thanks
Old May 21, 2006 | 01:43 PM
I always use a really big prybar.
If you want you can remove it from the Strut and install. Then reattach to the strut.
Old May 21, 2006 | 09:14 PM
med01e's Avatar
Got the Strut loose, but it doesnt want to move back in place. Could the axel or cv joint have slipped out? If it did - how do you get it back....
Thanks
Old May 23, 2006 | 12:41 AM
Possible the Inner Joint did. It should slide back in with a little bit of force.
dpvovo
Feb 18, 2019 07:41 PM
zero324
Feb 19, 2012 11:17 PM
suzkitch
Suspension
May 5, 2010 03:01 PM
KeithS60&V70T5
Nov 14, 2009 12:24 PM
indagutter
Oct 11, 2004 07:10 PM
