Belts
Old Sep 2, 2005 | 09:24 PM
JPizano23's Avatar
Default Belts
Hello, I'm looking at replacing the belts on my car, but I can't find out how. Is there a website that could guide me through the process? I've repaired my S80 a few times myself, I'm hoping i can continue
Old Sep 2, 2005 | 10:05 PM
Default RE: Belts
Are you planning on just doing the serp. belt? Or are you going to do the timing belt as well?
Old Sep 3, 2005 | 09:19 PM
JPizano23's Avatar
Default RE: Belts
I'm looking at doing the serpetine belt. The car only has 85,000 miles, should it be time I look at the timing belt as well?
Old Sep 4, 2005 | 01:32 AM
Default RE: Belts
Some will do it early and some will wait to 100,000 miles to do it.
You will need to remove the outer lower crank pulley to remove the belt.
There is also a tensioner you will need to turn to remove the belt from the pulleys.
rcoonce
Dec 2, 2007 09:51 AM
billofdurham
Feb 11, 2006 03:27 PM
colgate41
Jan 15, 2006 10:39 AM
blac70
Jul 21, 2005 10:30 PM
Daz_C70
Jul 12, 2005 06:29 PM
