Belts
Old Jan 15, 2006 | 03:37 AM
colgate41's Avatar
Default Belts
Hey all, my belts are making some noise and i would like to eather replace them or tighten them. Is this a hard job? Do i need any thing special? Thanks a lot. 91 740 Turbo 130K
Old Jan 15, 2006 | 03:52 AM
Red XC's Avatar
Default RE: Belts
No, the job should be easy. Just need to loosen the tensioners. You might just need wrenchs.
Is the noise to squealing? that would be the belts that are glazed.
Old Jan 15, 2006 | 10:39 AM
Default RE: Belts
It is easy. You will need a 13mm socket and wrench and a 10mm socket.
The 13mm is to loosen the nuts that hold the accessories tight and the 10mm adjusts the part.
rcoonce
Dec 2, 2007 09:51 AM
billofdurham
Feb 11, 2006 03:27 PM
JPizano23
Sep 4, 2005 01:32 AM
blac70
Jul 21, 2005 10:30 PM
Daz_C70
Jul 12, 2005 06:29 PM
