Bent values due to timing belt problem
Old Sep 20, 2010 | 04:14 PM
Sundhar's Avatar
Default Bent values due to timing belt problem
Hi,
Can anyone throw some light if diagnostics test can indicate problem with bent values? This way one need not think of replacing timing belt for a really used S80 T6 1999 make. What diagnostic test will reveal that there is problem with bent value. Thanks.
Old Sep 20, 2010 | 05:08 PM
537playing's Avatar
Compression tests for each cylinder
Old Sep 20, 2010 | 06:49 PM
Tyutyunnik's Avatar
+1
I had this happen on an old eclipse, cylinders with bent valves will show little to no compression depending on how extensive the damage is.
johnhon
Jun 1, 2025 08:40 AM
ingydrummer
Sep 19, 2014 05:24 PM
rbroy
Mar 24, 2008 09:51 PM
DaveNY
Nov 23, 2006 03:03 PM
