bent valves!
Old Apr 26, 2009 | 12:58 AM
kornerz's Avatar
Default bent valves!
hello everyone, today i picked up a 99' s80 with some engine problems . The timing belt skiped and it bent the crap out of some of the valves. I got a smoking deal on it so i jumped on it. Now, how hard is it to pull the head off and take care of this issue? i worked at ford for 4 years as a tech. Ive just never worked on a volvo. Watcha guys think? a couple of days?
Old Apr 26, 2009 | 06:25 AM
It is not all that bad just time consuming. Also it is best to make or find the rear cam lock tool. Then before you remove the front VVT pulley if you mark it correctly then it will go back together really easy.
Check out this post it is for a 5 cylinder but is the same as the 6 cylinder.
https://volvoforums.com/forum/volvo-xc70-17/how-repair-timing-belt-head-gasket-bent-valves-18322/
Old Apr 26, 2009 | 10:59 AM
kornerz's Avatar
ok, i took a look at it this morning. it looks like the serp belt got cought in the crank sprocket. I cant even see the sprocket because it has half the serp belt on it. is this a commom problem with the 2.9?
Old Apr 26, 2009 | 07:40 PM
Not common but something make it throw the belt.
Old Apr 28, 2009 | 01:34 AM
kornerz's Avatar
pulled it all apart this mornng. 12 bent intake valves. Dropped of the head at my local machine shop. its going to be fun doing the timing belt. i didnt mark anything because the guy i bought it off of messed with it. Anyone local wanna make some extra cash.... by timing it for me?
Old Apr 28, 2009 | 11:38 AM
kornerz's Avatar
i just called a local volve shop to see if they would time it for me because i dont have the specialty tools. They said theres no way to time it. He told me it will have to go the the dealer! wtf. how can it not be timed, i dont get it. i know its going to be a big pain in the azz but..... does anyone have the step by step to time it if nothing was marked? thanks for the help
Old Apr 28, 2009 | 06:55 PM
Make a tool to lock the cams then I can explain it to you from there.
Old Apr 29, 2009 | 02:04 AM
kornerz's Avatar
will do. Thanks tech.
Old Sep 7, 2011 | 12:21 PM
volvoedmonton's Avatar
i have locked the cams on my s80 now how do i time it
johnhon
Jun 1, 2025 08:40 AM
user 643973408324
Jan 6, 2009 07:51 AM
rbroy
Mar 24, 2008 09:51 PM
postdoc99
Feb 7, 2008 11:15 AM
