Bent valves in the head
Old Apr 21, 2007 | 06:06 PM
postdoc99's Avatar
Default Bent valves in the head
My engine runs rough since I had timing belt pulley failure. I was getting misfire error codes, but after I replaced thermostat and temp. sensor (It was a separate problem with constantly running fan) the CEL and error codes mysteriously disappeared and never came back. However, misfire-like behavior still remains, as it was since the day the car came back from the shop, after timing belt job. The engine performance is fine, I would not bother with it, but I my gas mileage deteriorated tremendously since the timing belt failure happened. I am getting 15 – 17 miles per gallon of premium gasoline. I was getting 28 – 30 miles before it happened. So I think I have bent valve(s) and think to swap the engine head. My car is 98 S70 with T5 engine. The head came from 1995 850 turbo. Would this head fit to my engine block? In a separate question, has anyone replaced valves? What kind of special tools do you need? Thanks a lot!
Old Apr 23, 2007 | 12:15 AM
Johnny Mullet's Avatar
Default RE: Bent valves in the head
Did the timing belt break before gong to the shop? These engines are no-tolerance and will grenade if the timing belt breaks.
Old Apr 23, 2007 | 12:27 AM
postdoc99's Avatar
No, it did not break. But it apparently jumped over few teeth off camshaft pulleys. The marks on camshaft sprockets were off when I took off plastic cover. The cover was ripped from inside.
Old Feb 7, 2008 | 11:15 AM
Paulie's Avatar
Just did a t5 that jumped a couple teeth. I pulled the head off and took it to my machine shop and let them go through it. When the car jumped time, it slapped all the intake valves against the pistons. they slapped to hard they gouged valve marks in the top of the pistons. Pretty straight forward job, biggest problem I had was the head bolts were seized in the block (steel w/aluminum and no anti-seize...) I broke 3 craftsman 14's and one impact socket getting the damn things out. Once I got through that I was ok.
The other problem I had was once I got the head off, I found every last vacuum line and piece of rubber in the engine bay was complete garbage. Some of that stuff would have been nearly impossible to see or fix with the intake and head on.
Price wise I spent $500 redoing the head with 10 new valves, and another 500 on hoses, lines, motor mounts, etc. First time doing the job, it took a day to take it apart and a day to put it back together.
That was my experience with it, I think the best thing you could do for yourself is run a compression check and see what you get from that first.
P
johnhon
Jun 1, 2025 08:40 AM
oblidi
Jan 1, 2015 01:27 PM
MaxOrbit
2001-2013 model year V70
45
Jul 29, 2013 09:08 PM
user 643973408324
Jan 6, 2009 07:51 AM
rbroy
Mar 24, 2008 09:51 PM
