Bluetooth problems
Old May 20, 2006 | 03:36 PM
JCVolvoS80's Avatar
Default Bluetooth problems
I recently acquired and installed a Bluetooth handsfree kit for my 99 S80 2.9. Everything works perfectly except the microphone. Also there are some..um...problems... O:-)
1) Microphone has absolutely no sound going through.
2) I removed the side door seal panel that covers the Side Curtain Airbags. In doing so, I stripped a small plastic bolt that hold it on. This need to be replaced ASAP.
3) Under-dash on the passenger side will not go back in and I cannot line up the vertical clips.
4) Side note, my sunroof started to rattle. I recall there being a post about it a while back but I forgot the fix. Any suggestions?
Old May 20, 2006 | 03:59 PM
Default RE: Bluetooth problems
2 and 3 anyway you can post pics?
4. make sure the cross bar isn't loose causing the rattle. If they are not loose then try to tighten the screws for the glass.
Kentor
Dec 24, 2018 01:33 PM
ignat
Jun 1, 2011 02:37 PM
psman
Feb 26, 2007 06:56 PM
nate2631
Oct 30, 2006 03:05 PM
admannj
Jul 16, 2006 08:15 PM
