bobcat
Old Mar 15, 2012 | 01:34 PM
Falasi4's Avatar
Default bobcat
Tue night a bobcat ran out on the interstate right in front of me and I nailed it without even having a chance to lift the throttle. Messed up a bunch of the plastic bumper junk and bent the crud out of the A/C condenser. Had an estimate yesterday and further inspection revealed the radiator is also bent.
On the up side the car is still ok to drive - no apparent leaks... yet....
I cobbled the plastic bits together secure enough to get around until the repairs can be scheduled.
Any concerns over getting a new A/C condenser and Radiator? I hate to get them changed if they are not leaking but they are really bent and I suspect possibly to the point of imminent failure. (The A/C is bent to the point of touching the radiatior along the bottom)
Old Mar 15, 2012 | 06:38 PM
donf's Avatar
If you're a few hours from home some Christmas Eve and your AC goes out it's usually not a big deal, your radiator on the other hand.........
That said, I live in Texas and the AC is pretty important. Get everything fixed, call your ins.agent, don't let PETA hear about it and you'll be happy
Old Mar 16, 2012 | 10:24 AM
Falasi4's Avatar
Something else I just noticed - the outside temp reading is not working.
Is there a sensor somewhere in the nose that may have been disconnected/destroyed??
Old Mar 16, 2012 | 01:25 PM
donf's Avatar
On older 80's Behind the bumper fascia "L" shaped bracket with the sensor attached - most likely where you hit the late feline.
