Boost controller?
Old May 4, 2009 | 09:59 PM
4g63's Avatar
Default Boost controller?
I think I am having problems with my TCV. The car fluctuates at mid throttle. Thought maybe it was the ETM but when you shift into 2nd or 3rd the fluctuation remains. I am planning on adding a boost gauge later this week so I can see if it matches the fluctuation, but in the meantime was wondering if I can simply replace the TCV with a manual boost controller, and set it to stock levels. Any imput would be appreciated.
Old May 4, 2009 | 11:22 PM
kevmcrae's Avatar
Do you know if you already had the software update done by the dealer? You may also want to remove your throttle body and clean it out with TB cleaner. It tends to get carboned up from the PCV hose. Although normally that just effects lower rpms.
Old May 5, 2009 | 06:53 PM
The ME7 cars do not like MBC's the computer still sees the over boost and cuts it back.
559s40
Jul 13, 2012 10:50 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
Bobalob
Jun 30, 2005 01:48 PM
Turbovolv85023
Apr 13, 2005 06:04 PM
