Boost Controller and the TCV?
Old Dec 1, 2007 | 07:35 PM
Lab_Rodent's Avatar
Default Boost Controller and the TCV?
I hooked up my boost controller and gauge. THey are doing their job. But boosting can sometimes be sporadic. Plus I never get any negative vacuum to the gauge. Only thing that could possibly be causing the no vacuum could be the TCV. Anyone know exactly what this does and how it works.
Lab_Rodent's Avatar
Default RE: Boost Controller and the TCV?
btw TCV = Temp Control Valve
Old Dec 2, 2007 | 12:55 AM
Lab_Rodent's Avatar
I will go ahead and answer my own question for all who reads. The TCV (Temp Control Valve, aka Turbo Control Valve, aka Turbo Control Solenoid) is located in the line going to the waste gates. It regulates air and wut not. Anyway... it seems that it is best to unhook it and bypass it if you hook up a MBC. It will make boosting smoother. When upping the boost, the air pressure is out of its range to handle and it sort of freaks out. Someone on one of these forums said they were getting a noise in their cabin on the left hand side when they hooked up their MBC. It was because they didnt bypass the TCV and the relay that controls it is under the dash to the left, it will click rapidly causing a light fluttering sound.
Old Dec 2, 2007 | 09:02 AM
Thanks for updating the post. Very useful info.
Do you have any pics of the setup?
Old Dec 2, 2007 | 03:03 PM
Lab_Rodent's Avatar
Now I do,... Here is my stealth type set up.
Boost Controler
Boost Gauge
Here is the connector peice I used to bypass the TCV
and the BOV (which has the annoying whistle on it (its removable). I figured it would be usefull for atleast being able to hear when it opened up. I have yet to hear it whistle because I swear the BOV never goes off.)
Old Dec 2, 2007 | 07:06 PM
gordon368's Avatar
hmmm Now I want to do thatto my volvo
thats so cool
Old Dec 2, 2007 | 08:33 PM
If you go into full boost the let off the gas fast you can't hear it?
Old Dec 4, 2007 | 01:09 AM
Lab_Rodent's Avatar
No, I have tried. Plus I watched the gauge when doing this and all was normal. No signs or sounds from the turbos ether conserning back pressure. The throttle body is electronicly controlled, I was thinking that had something to do with it. Because it prolly' wont slam shut like a normal TB would.
Old Dec 5, 2007 | 05:52 PM
I was driving a TT yesterday after installing new turbo's and I could hear the factory ones by boosting and letting off the gas.
Big you bypass the factory ones?
Are you running both setups?
Old Dec 5, 2007 | 08:43 PM
Lab_Rodent's Avatar
No CBV if that is what you mean?
Old Dec 5, 2007 | 10:10 PM
Does that mean you bypassed or no?
If you didn't then that may be why you can't hear the valve it might be to quiet because you have 3 things releasing pressure at the same time.
Old Dec 6, 2007 | 03:27 AM
Lab_Rodent's Avatar
the CBV was replaced by the BOV
Old Dec 6, 2007 | 06:14 PM
Oh ok Im supprised you can't hear it.
I hear the factory setup all the time.
Have you connected a vaccum guage to make sure it is receiving vaccum to open? (Or the other way around)
Old Dec 7, 2007 | 02:03 AM
Lab_Rodent's Avatar
Yeah, I did it the "proper" way just to replace the stock CBV. The "vacuum" line in all actuality keeps the thing closed unless the throttle body slams shut. Which who knows when it comes to that because it is electronicly controlled. The way it is programmed hurts mid throttle performance. I can tell that (to put simply) it doesnt put the power out unless you put the peddle all the way down... [holding back from ranting[:'(]]
Old Dec 7, 2007 | 06:01 PM
Ok sorry it isn't working the way we think it should.
559s40
Jul 13, 2012 10:50 PM
Holedigger
Dec 9, 2011 02:54 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
imhereftw
Nov 15, 2009 02:56 PM
