Boost hoses
Old Jun 13, 2015 | 03:27 PM
Vicious942's Avatar
Default Boost hoses
Hello everyone,
I have a 2003 s80 with 167,000 miles on it. Car needs a bit of work and I was hoping you experts could give me a few tips/advice.
Recently, the check engine light came on. Went to a car mechanic nearby and they performed a Coolant Temperature Sensor Test, Turbocharger and Cooling System Pressure Test.
Part of their receipt is the repairs and results of tests.
Turbocharger Boost Pressure:
Boost hoses are starting to leak, recommended tightening clamps and retesting. Will likely require replacement of boost hoses.
What the turbo hoses are that they're talking about? and what I need to do to clean/fix them?
Coolant Temperature Sensor:
Sensor requires replacement.
Cooling System Pressure Test:
Upper radiator hose needs replacement.
Additionally, I've recently had issues in starting the car. I'll turn the key and it will take about 4 or so seconds to turn over. What is the problem?
Thanks,
Vicious
trackstar
Feb 6, 2015 09:07 AM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
