Volvo No Start
Old Jun 13, 2015 | 04:05 PM
BlackVolvos80's Avatar
Question Volvo No Start
I recently purchased a 2001 Volvo S80. It has had a hard start from the second I purchased it, but being as though I am pretty savvy with cars I assumed a good tune would fix it. Well before I could even get to performing a tune up, the car decided it no longer wants to start. Since then I have checked codes and got a p0717 "Transmission related code" I pulled the etm out and cleaned it. within the etm itself was a mess of motor oil which I cleaned out, not sure how oil ended up inside of it? The etm has a yellow sticker from 2005. I replaced spark plugs and checked spark which checked out good. Fuel pressure jumps to a little over 50 psi when priming. I replaced the battery which was still under warranty. I have checked every relay with a external 12v battery and can hear each one click. Starter works well and cranks hard. I have checked all grounds and fuses. Timing belt looks good. Now for the weird part, when I go to put the car in the ON position immediately the etm will start clicking constantly and the fuel injectors also start to spray as well as a clicking sound from fuel pump relay. Also the tach jumps up and down with the key switched to the on position. If I crank the car for over 6 seconds I will always get a backfire from the intake. This car has me so confused and all the shops I call do not want to work on Volvos. The car only has 101,000 miles on it and everything looks in great condition. Thank you so much for your help
DecalService
Dec 4, 2019 10:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
WagHag
Dec 2, 2007 08:45 AM
auser
Nov 20, 2004 10:27 AM
