Brake Warning Light.
Old Jun 12, 2008 | 10:30 PM
bluedevilbill's Avatar
Default Brake Warning Light.
Hi, all.
I was driving my 2006 S80 home last night, braking very (very)hard off the highway. Upon breaking, I got a red Brake Warning message: "Brake Fluid Low: Urgent Service Needed" and the brake light illuminated. No change in braking feel.
When I let off the brakes and came to a stop, the warning went away. When I checked the message screen, I got a "No Messages" indication. Car has been fine since.
Any thoughts on what happened? Any insight is appreciated. Thanks!
Bill
Old Jun 13, 2008 | 06:02 AM
bigern45's Avatar
Default RE: Brake Warning Light.
you may be right on the threshold of what is allowable and not as far as brake fluid level. very heavy braking and an almost empty brake reservoir might allow physics and gravity have that fluid shift forward and the sensor become open momentarily, turning the light on. then when you go to normal g forces the fluid level floats back and re-closes the sensor. id have the brakes checked because usually light on means fluid is low due to pads being close to worn out. if your pad is fine then top off the fluid in the reservoir and see if that takes care of the light.
Old Jun 18, 2008 | 05:42 PM
Thanks!
glixons
Jan 4, 2015 06:15 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
97-850Wagen
Sep 10, 2013 10:40 AM
MaZoN
Aug 5, 2008 06:52 PM
Gordon
Jun 28, 2007 09:26 AM
