BRAKES re Torque specs for caliper bolts?
Old May 5, 2013 | 08:38 PM
Johnson1's Avatar
Default BRAKES re Torque specs for caliper bolts?
I have a 2005 s80 and need to replace the rear brake pads. Do you know what the torque specs are for:
Caliper mounting bolts for
-read caliper
Caliper mounting bracket bolts for
-rear mounting bracket
Thanks!
Old May 28, 2013 | 04:08 PM
tenui's Avatar
Ever get an answer? I need them for front/rear as well...
-john
Old May 30, 2013 | 07:46 PM
75ohm's Avatar
I've got access to get this info but it will take me until tomorrow... I'm doing the 2008's rears tomorrow night so will double check 2005... hang tight.
Old May 30, 2013 | 08:24 PM
tenui's Avatar
Sorry, I should have specified. I need the 2008 w/o the EPB.
Also, I asked this in another thread, but since your doing the 2008 as well, is there a trick to getting an impact hammer or breaker bar enough room to loosen the caliper bolts? There doesn't seem anyway to get the power tool in there and I'm only getting about 3 degrees of rotation with the breaker bar.
Thanks in advance for any help!
Old May 30, 2013 | 08:55 PM
ES6T's Avatar
You could have just removed the 13mm bolts for the caliper by now and been done with it. Its gotta come off to do the pads anyway.
Old May 30, 2013 | 09:02 PM
tenui's Avatar
I "can't" remove the bolts... that's the problem. They are too tight for anything but the breaker bar. I don't have any clearance for the impact wrench. The flange around the lower arm is preventing a decent sized ratchet from being used. My box end wrench doesn't have enough leverage.
Old May 31, 2013 | 07:04 AM
ES6T's Avatar
Are you talking about the pad retainer bolts that hold the retaimer bracket to the spindle or the caliper bolts that hold the caliper to the bracket?
Old May 31, 2013 | 01:42 PM
75ohm's Avatar
For the 2008... can't confirm for 2005, apologies:
FOR THE REAR:
mount rear brake caliper, 110 Nm
rotor to hub, 35 Nm
two listings:
slide rail rear brake caliper, 28 Nm
slide rail rear brake caliper, 35 Nm
FOR THE FRONT:
Slide rail front brake caliper, 28 Nm
75ohm's Avatar
Agreed, can't picture what is attempting to be done...
Old Jun 1, 2013 | 03:56 PM
75ohm's Avatar
2008 was 2x15MM, box wrench and a rubber mallet to move it along... for fun, I tried the 1/2" impact with a wobbler, worked fine... can you post a pic?
I could even sneak a 1/2" 15MM socket in there on a 1/2" driver...
CT4
Feb 16, 2017 02:25 PM
donzi16
May 31, 2012 09:16 AM
240DLman
Dec 6, 2009 04:39 PM
anotherskait@yahoo.com
Sep 8, 2009 11:55 PM
mirubbish
May 10, 2007 12:38 PM
