Bright passenger headlights
Old May 29, 2013 | 11:34 PM
RTyson's Avatar
Default Bright passenger headlights
I just bought new sylvania H7 headlights for both sides and the headlamp on the passenger side is significantly brighter than the driver side. Has anyone ran into this issue? One things i notice is that the inside of the passenger side headlight case is foggy, but that is the side that is brighter.
Old May 30, 2013 | 04:34 PM
akabond's Avatar
hmm i have never heard of that. can you take some pictures for comparasion.
few things i can think of:
1) make sure the bulbs are tightly secure and not out of alignment
2) might have to do some electrical diagnosis with a volt meter. or have it checked by a mechanic or check the ground wire
3) make sure the wires are not loose. just follow the drivers side wires to make sure its all tighten
4) also i suggest swapping the bulbs and see if the low brightness still there
Old Jun 7, 2013 | 02:25 PM
RTyson's Avatar
mechanic said the light was not grounded correctly. Thx anyways the lights were drastically dim on one side, super bright on the other side.
emacsp
Nov 8, 2013 07:20 PM
VDriver24093
Feb 21, 2011 04:35 PM
roughyear
May 22, 2006 02:45 PM
baldy7
Dec 21, 2005 02:30 PM
Rich Solano
Apr 21, 2005 09:54 AM
