cabin air filter
Old Jan 5, 2009 | 04:33 PM
volvos8087's Avatar
Default cabin air filter
when should you replace the cabin air filters, 2000 s80
Old Jan 5, 2009 | 07:02 PM
jlewisinsyr's Avatar
Default RE: cabin air filter
I believe it is every 15,000 miles (every other maintenance schedule).
Old Jan 6, 2009 | 09:22 AM
75ohm's Avatar
Easy to get to... yank it out and see if it is dusty or smells... and replace if needed!
Old Jan 6, 2009 | 06:20 PM
andrei3333's Avatar
i believe our cars have two different types of cabin filters, how to identify which filter my car uses ?
Old Jan 6, 2009 | 06:36 PM
JTapper's Avatar
If your recirculation button says "aut/man" on it then you have the charcoal type filter. If it's simply an on/off button then you probably have the regular. Safe bet, for the few $ difference buy the charcoal one. It will fit in the housing no matter what system you have, you just remove a plastic tab.
Old Jan 6, 2009 | 09:29 PM
volvos8087's Avatar
where the heck is the cabin air filter box at
Old Jan 6, 2009 | 10:16 PM
andrei3333's Avatar
frotn passenger, under the glove box somewhere i think
Old Jan 6, 2009 | 11:21 PM
Crito's Avatar
Banned
Its actually quite a pain in the **** to replace. I had to remove the trim piece on the passenger side of center console to remove the other trim piece under glove box. Then I had to buy a stubby ratchet and a set of greatneck torx socketsw to unscrew the two screws in the back of the box because they were too close to the floorboard for my torx screwdriver. Finally popped open the box to find there was no filter in there at all. LOL. I bought a cheap, non-charcoal, one on ebay for like $10.
debargha
Feb 24, 2015 10:46 PM
nigel_miguel
Jan 7, 2012 05:09 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
