Can't Tighten Ball Joint
Old Apr 29, 2010 | 09:04 PM
trebuchet5684's Avatar
Default Can't Tighten Ball Joint
I'm trying to finish installing new ball joints. The old ones had torx fittings on the ends of the studs to hold it still while tightening/loosening the nut. The new ones do not have the torx fitting. I was able to tighten the driver's side without it and (apparently) without turning the stud. However, on the passenger's side, the stud turns and the nut doesn't tighten. How do I tighten that one?
Old Apr 30, 2010 | 09:45 PM
You can put a jack under the control arm and put some pressure on it. Then try to tighten it.
dpvovo
Feb 18, 2019 07:41 PM
silkhope
Oct 4, 2013 08:31 PM
meusman
Aug 30, 2010 07:10 PM
parmbrust
Oct 18, 2009 07:29 AM
cw9000
Jun 18, 2009 08:15 PM
