check engine results
Old Mar 3, 2010 | 09:10 PM
ROJAS80's Avatar
Default check engine results
so ive had the check engine light on for a while. i havent taken it to the dealer to get fixed bc they charge 250 just to look at it. so i found a shop that works on swedish cars and got it checked there. here are the results 1. ecm-1600 one of the o2 sensors in front 2. ecm-1600 boost pressure signal 3. ecm-170f atmospheric pressure sensor/ boost/ pressure sensor fault and to fix all this is about 500 bucks or a 1.5 of my paycheck. anyone know the parts i need and if ill be able to fix myself? or am i better off paying the 500 bucks cause i got a lil mechanical knowledge so what do you guys think?
Old Mar 4, 2010 | 08:58 AM
NoLifeTilBoost's Avatar
You can replace the sensors yourself easy enough. The front O2 is a pain to get to and involves dropping the exahust, but not complicated. The real question is are the sensors actually the problem.
How has the car been behaving?
wheelsup
Feb 13, 2009 09:58 AM
twowheelin
Oct 7, 2008 10:23 PM
spunkymonky
Aug 14, 2008 08:21 PM
volvonewb
May 7, 2007 09:09 PM
rp850
May 13, 2006 08:39 PM
