Cooling Fan won't start
Old Jul 9, 2013 | 06:16 PM
craigy's Avatar
Default Cooling Fan won't start
I have a 1999 S80 2.9 cyl Volvo.......the cooling fan will not start up even after the car has been left running for a while.....
Old Jul 9, 2013 | 06:24 PM
Does the fan come on when the AC is turned on? If not, you have a problem.
The electric fan is suppose to come on when the motor reaches about 216 degrees F and turn back off at about 205 degrees. So, unless you are sure the motor is above 216 degrees, don't worry about it.
Old Jul 10, 2013 | 07:53 AM
craigy's Avatar
Thank u RSPI.....Fan still not coming on....car has 153,000mls....Coolant, Thermostat and gasket and Radiator were all replaced......if there is a relay for this fan, can u advise where it's located.......1999, S80, 2.9
Old Jul 17, 2013 | 03:39 PM
liljohnny's Avatar
Default slow turning fan
My fan turns slow wen car is off. I will overheat in hot weather and traffic. Do I need a new fan or temperature sensor?
Old Jul 18, 2013 | 08:02 AM
craigy's Avatar
Help!!!!! We hav changed Radiator, Thermostat & Gasket, Temperature Sensor, Coolant Sensor and the Cooling Fan is still not coming on......is there a Temperature switch that turns on the fan......where can we find relay for fan.....1999 S80, 2.9
Old Jul 18, 2013 | 08:58 AM
doublebug's Avatar
have you checked the wires?
Also There can be faulty control module on the fan.
Have you tried to force fan to be on using dealer computer?
Old Jul 18, 2013 | 05:07 PM
torontos80t62000's Avatar
I had the turbo air pipe fry the cooling fan relay wire ......I got a used engine/cooling fan for 100 bucks and did the repair in about 20minutes.......if you need a step through I can definetly help you buddy...
I went through the exact same issue with the fan module relay return wire . All it was , was an exposed wire....
... y should I half to buy the hole unite when I need a simple wire. The truth is I had to bite my lip and spend the hun . My advice find a used one the repair is very simple..four screws and it slids in. Mine was off of an 01 non turbo with 120 thousand on it ..hope this helps $$$ factor
Old Jul 20, 2013 | 07:31 PM
Disco2's Avatar
Had the same issue. After hooking up jumper wires to the fan and seeing it worked, I assumed the control module was bad and replaced it. Got one for $15 from the junk yard. Spliced it in and works great. Real easy to replace. (4 torx screws)
Old Jul 23, 2013 | 02:15 PM
craigy's Avatar
Default Thank you
Thank you Disco2.....our problem was surely the module, but we found a fan in good condition at the junk yard for only $20 and ...bingo.....the fan is working....thanks again, appreciate...
Old Jul 23, 2013 | 02:18 PM
craigy's Avatar
Thank you Disco2....we found an entire fan in good condition for $20.....and bingo its working....appreciate ur response
Old Jun 2, 2021 | 06:17 AM
Anjum1982's Avatar
Default Coolant fan not works automatically
I have a volvo s80 2005 turbo and its coolant fan does not works automatically but when i start air conditioning than the coolant fan works,
And if my car is heatup and i switch it off and than start the engine again than coolant fan start automatically for a while.. please tell me whats that problem..
Quick Brick
Dec 22, 2021 11:41 PM
craigy
Jul 18, 2013 08:56 AM
elouadj
Jun 25, 2008 07:00 PM
la verite 4l
Jun 14, 2008 09:54 AM
la verite 4l
Jun 12, 2008 05:02 PM
