electric cooling fan won't start
Old Jun 10, 2008 | 08:00 PM
la verite 4l's Avatar
Default electric cooling fan won't start
i was idling in a parking lot the other day and smoke started to billow out from under the hood, i immediately shut the car off and popped the hood. the smoke smelled electrical and was coming from the electric cooling fan motor. so i uninstalled it and found that the motorhad seized up, so iordered a new one which arrived today, i installed it and connected all of the wires and started the car and let it idle. the temperature kept going up but the fan never kicked on, when i tested the relay it was showing that there was no power getting to the relay. Is there a fuse for the fan relay? could i have melted a wire or something else electrical, why won't the fan turn on? any help would be greatly appreciated as i am unexperienced with volvo's and can't afford to take it to a garage. please help
thank you for your time
Old Jun 10, 2008 | 10:12 PM
Default RE: electric cooling fan won't start
Did you check all the fuses?
No power at all to any of the wires?
Old Jun 12, 2008 | 07:26 PM
it's a 1995 850 GLT yesterday i tested the cooling sensor and it tested positive that there was power and when i unplugged it the fan started immediately
when i plugged the sensor back in the fan immediately turned off
i ordered a relay online but when i tried running the car without the coolant sensor it ran very poorly and barely started
i took the red wire from the relay and used a jumper to one of the wires thats connected to the electric fan and the fan started right up
Old Jun 12, 2008 | 07:43 PM
When the fans burn up it usually takes the relay out.
Also if it overheated you might want to replace the thermostat.
Old Jun 14, 2008 | 09:54 AM
Psaboic's Avatar
+1
Quick Brick
Dec 22, 2021 11:41 PM
bcolins
2001-2013 model year V70
Oct 24, 2013 09:13 AM
troys1992v240
Aug 11, 2012 11:35 AM
codynidaho
Jun 6, 2011 10:02 AM
la verite 4l
Jun 12, 2008 05:02 PM
