Cruise Control Issue
Old May 8, 2006 | 02:15 PM
dinopix's Avatar
Default Cruise Control Issue
I have a weird problem that just popped-up. Sometimes my cruise control won't come on, but if I stop the car and re-start it, the cruise control works just fine. I am not sure if it is has been doing this for a while, since it is obviously intermittent, but I just noticed it after having new rotors and pads put on.
Has anyone else ever had this happen or have any idea what might be causing it?
Old May 8, 2006 | 08:51 PM
Default RE: Cruise Control Issue
Is the Check engine light or the ABS light on?
Old May 9, 2006 | 02:49 PM
dinopix's Avatar
There are no warning lights on. Is there any way that the wheel sensors would affect the cruise control? This happened right after I had the brakes replaced and the wheel sensors on the front are the only things that I can think of that might possibly have anything to do do with the cruise control not working properly after having the brakes done.
Old May 9, 2006 | 09:20 PM
Alot of things on these cars will disable the Cruise Control.
Try this to see if there is codes in the system. If it is a 1999 it may not work.
Push and hold your Read button on the end of the turn signal stalk. While holding it push and release the Rear fog light switch 2 times and the Display on Dash should say reading DTC's
It will only tell you if there is codes in a system and nothing else.
See if it says there is any codes in any modules.
MrStiv
Sep 23, 2013 07:20 PM
StanP
2001-2013 model year XC70
Nov 2, 2012 09:55 AM
rspi
Mar 7, 2010 06:13 PM
rocknrubi
Feb 24, 2010 03:24 PM
jfikentscher
May 31, 2006 09:58 PM
