Dipping Bulb Malfunction
Old Jul 25, 2006 | 10:03 PM
badgers's Avatar
Default Dipping Bulb Malfunction
I'm a new (preowned) S80 owner. The message console informed me that I had a "bulb malfunction dipping beam" this morning. Anyone have any idea what a "Dipping Beam" might be?
Old Jul 25, 2006 | 11:00 PM
Default RE: Dipping Bulb Malfunction
That is one of the Headlights are burned out.
Old Jul 25, 2006 | 11:02 PM
althej's Avatar
had the same thing, check all the lights, headlights, corners, turn. everything.
Old Jan 29, 2008 | 11:13 PM
BW505's Avatar
My mom car has the same problem. The thing is I replaced both headlights and checked all the fuses. The headlights still won't work!! What's going on?
Old Jan 30, 2008 | 05:50 PM
ORIGINAL: BW505
If teh bulbs and fuses are good then you need to check the shunt in the main computer under the dash.
Old Jan 31, 2008 | 05:35 AM
sophisticars's Avatar
Agree with tech,
There is a set of shunts (like big fuses) under the dash on the drivers side.
I used to go through these for fun and realised that the main bulbs in the headlights where a xenon type and were drawing too much current and heated up the shunt melted the plastic and therfor the fuse on the shunt.
It can aslo happen if you upgrade the sidelight bulbs as well.
There are ways round altering the shunt by drilling a hole in it, but i decided not to risk it and just replaced the shunt and bulbs and hey presto cured!
Shunts are volvo only but only cost about £3 uk
carrottop
Dec 22, 2014 08:46 PM
ShowTek
Nov 1, 2011 04:20 PM
expert2929
Mar 27, 2011 12:35 PM
rsylvester07
Aug 12, 2010 12:12 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
