Dipstick problems S80 T6
Old Oct 8, 2010 | 08:59 PM
commops106's Avatar
Default Dipstick problems S80 T6
Ok guys and gals just bought 04 s80 t6 61150 miles, checked oil because im **** with my cars dip stick has brownish tint on it is that the beginnings of sludge? I pulled the crank case oil cap and a crusty brownish buildup is on the metal. Also i don't believe it was in my owners manual were should the oil be on the dipstick between the 6 X's or the top X is each X 1 quart of oil? my oil fell alittle over the third X does that mean 3 quarts low?
Old Oct 27, 2010 | 06:13 PM
Detrinova's Avatar
Default your answer
those engines take 6.5qts of oil. each of those x's is for 1qt and with your turbo you should keep it full all the time. that brownish tint is normal when you let it get low like that.
Old Nov 3, 2010 | 12:46 PM
jmallie's Avatar
Are you sure that each X is a quart? I always keep it topped up but I had assumed the entire hatch area was one quart. All my other cars (mazdas, BMW etc) have similar hatch marks but the whole thing is 1 quart.
The most I recall being down is 1/3 quart but that showed two xxs low as I recall.
I can check Valdis when I get home.
Regards
Old Nov 3, 2010 | 08:13 PM
jmallie's Avatar
Per manual looks like 7.3 quarts in the 2.9 or 2.9 turbo. The whole 6 Xs look like 1.6 quarts.
christian amezquita
Mar 10, 2015 06:48 PM
Maxfli
Mar 3, 2013 11:34 AM
Marks 240
Dec 6, 2005 08:48 PM
bumblebee03
Sep 8, 2005 11:39 PM
POR2
Jun 17, 2005 07:34 PM
