Trans dipstick tube
Old Dec 5, 2005 | 03:47 PM
Marks 240's Avatar
Default Trans dipstick tube
Hi everybody,
How on God's green earth does one get apart the fitting where the automatic transmission dipstick tube fastens to the pan? I assume it's standard thread (Counter clockwise to remove). I hold the pan side with a large open end wrench and try to loosen the tube side with another open end and it won't budge. I've soaked it overnight with PB bolt loosener, still no luck.
I have to replace the kickdown cable and need to drop the pan.
Does any one know what metric sizes these two are and if /where box wrenches with a slot opening are available?
Any secrets or tricks to this one?
Thank you,
Mark
Old Dec 5, 2005 | 08:55 PM
Default RE: Trans dipstick tube
They are a major pain.
If all else fails remove the 2 starter screws and and then drop the pan with the tube.
Thats what I always do.
Old Dec 6, 2005 | 01:10 PM
Marks 240's Avatar
Thanks Tech,
After looking at a few articles on the web and careful consideration, that's probably what I will do rather than risking damaging the tube or the pan. I want to get the starter off anyway. I was thinking of using this method to hold the crankshaft still while removing the crankshaft bolt and pulley for installing new rubber cam follower silencers. What do you think?
I was going to make a tool for Method 2.
http://www.volvoclub.org.uk/faq/Spec...rankHolderTool
Thanks again,
Mark
Old Dec 6, 2005 | 08:48 PM
That sounds pretty cool. I like the idea of that tool.
bcolins
2001-2013 model year V70
Oct 28, 2013 10:55 AM
98_V70_T5
Jul 1, 2012 11:41 AM
sly_fox
Nov 17, 2011 09:53 AM
Beau98
Aug 16, 2010 10:10 PM
crashin
May 24, 2010 04:56 PM
