DSTC light wont shut off
Old 11-17-2008 | 06:03 PM
mischief4l's Avatar
Default DSTC light wont shut off
The DSTC light won't shut off by the fan controls. I have searched the forums. As I understand it, you press the button 5 deliberate times to shut if off, but it won't shut off.
Every once and a while, when I start the car, there is a DSTC Service Required message on the screen, but if i shut the car off and turn it back on, it goes away.
DSTC does work though like when I am making tight turns or fast acceleration from a full stop, you see the orange indicator flash in the dash.
Is there anyway to disable it manually like pulling a fuse? Or maybe even reset a computer?
Old 11-17-2008 | 06:09 PM
vegasjetskier's Avatar
Default RE: DSTC light wont shut off
Try holding the button down for 3 seconds.
Old 11-18-2008 | 03:03 PM
mischief4l's Avatar
I actually tried 5 seconds and no changes. I remember a post where someone was like deliberate presses, so that what I meant...a long press. Any other suggestions?
Old 11-18-2008 | 03:40 PM
From the owners manual:
Dynamic Stability Traction Control (DSTC)
The DSTC system performs all of the functions of the STC system. In addition, DSTC also applies the brakes to one or more of the wheels to help maintain stability if a wheel begins to lose traction. The system functions at speeds above 12 mph (20 km/h) and works on all four wheels, on any road surface. When DSTC is active, brake pressure is regulated automatically and the brake pedal will move slightly. If you press the brake pedal while DSTC is automatically regulating brake pressure, it will feel stiffer than normal. A pulsating sound will be audible at this time, which is quite normal.
Switching off DSTC
Normally, DSTC should be switched on at all times. If for any reason the steering wheel position or the front wheels are not properly aligned, DSTC should be switched off since the system may receive incorrect signals.
When the LED in the button is on, this indicates that DSTC is switched on (the light will also come on if a fault has been detected in the system). To avoid inadvertently switching the system off, the button must be pressed for at least one second before DSTC is deactivated.
The symbol will come on to indicate that DSTC has been switched off. The system is automatically switched on when the engine is started.
The DSTC indicator light () will flash when:
DSTC is actively functioning to help avoid loss of traction.
The DSTC indicator light () will stay on when:
The car is started (for approximately 2 seconds as DSTC performs a self-diagnostic test).
DSTC has been switched off by pressing the DSTC button in the middle console.
DSTC has been temporarily switched off due to high brake temperature. The system will automatically switch on again when the brakes have cooled.
If the system has been switched off due to a fault. An authorized Volvo retailer should check the system.
FAMAROTTA
01-03-2015 03:58 PM
rjaydodson
03-06-2013 08:15 AM
Pyrate
06-15-2009 03:17 PM
neill1223
12-21-2008 11:15 PM
moros323
07-26-2008 10:00 AM
