DSTC service light?
I've noticed my breaks have been a bit jerky, i might have the brake system bled since i don't know anything about my cars service records, I know that my axles are really bad and that I need an alignment as well, I'm not sure if this is playing a role in the DSTC light coming on intermittently, when i last took it to the dealer they didn't bring anything up about it despite the fact, but now the check engine light just came back, so gotta pay that 100$ diagnoses fee all over again i guess as soon as i get my suspesion and axles squared away. maybe it could be an electrical flaw?
looked this up in the manual
Dynamic Stability Traction Control (DSTC)
The DSTC system performs all of the functions of the STC system. In addition, DSTC also applies the brakes to one or more of the wheels to help maintain stability if a wheel begins to lose traction. The system functions at speeds above 12 mph (20 km/h) and works on all four wheels, on any road surface. When DSTC is active, brake pressure is regulated automatically and the brake pedal will move slightly. If you press the brake pedal while DSTC is automatically regulating brake pressure, it will feel stiffer than normal. A pulsating sound will be audible at this time, which is quite normal.
Switching off DSTC
Normally, DSTC should be switched on at all times. If for any reason the steering wheel position or the front wheels are not properly aligned, DSTC should be switched off since the system may receive incorrect signals.
When the LED in the button is on, this indicates that DSTC is switched on (the light will also come on if a fault has been detected in the system). To avoid inadvertently switching the system off, the button must be pressed for at least one second before DSTC is deactivated.
The symbol will come on to indicate that DSTC has been switched off. The system is automatically switched on when the engine is started.
The DSTC indicator light () will flash when:
DSTC is actively functioning to help avoid loss of traction.
The DSTC indicator light () will stay on when:
The car is started (for approximately 2 seconds as DSTC performs a self-diagnostic test).
DSTC has been switched off by pressing the DSTC button in the middle console.
DSTC has been temporarily switched off due to high brake temperature. The system will automatically switch on again when the brakes have cooled. If the system has been switched off due to a fault. An authorized Volvo retailer should check the system.
Switching off DSTC
