Engine/Compartment Fan turns on randomly while car is shut off
Old Nov 17, 2008 | 04:57 PM
mischief4l's Avatar
Default Engine/Compartment Fan turns on randomly while car is shut off
Sometimes after I leave my car for a period of time, I come back to find the blower running. Its not the fan in the front of the engine but the fan between the engine and the passenger compartment (i.e. A/C). Its only shuts off after I put the key in the ignition and move it to position #1.
I know the engine has a "turbo timer" where the fans keep going after the car shuts off to cool down the engine, but like I said, this is hours after I have shut off the car and when I did shut off the car, the fans weren't blowing.
Old Nov 17, 2008 | 05:08 PM
nicolaselias's Avatar
Default RE: Engine/Compartment Fan turns on randomly while car is shut off
It is a feature of the car to keep the interior cool when it hits a certian temperature. I have also heard that it does this sometimes to prevent frosting. The fan doesnt stay on indefinitely however as it will cut off long before it significantly drains your battery..
All in all, a rather smart feature if you ask me...
Old Nov 17, 2008 | 07:55 PM
75ohm's Avatar
I believe that it is 45 minutes after shutoff... but I could be mistaken here...
Old Nov 17, 2008 | 08:28 PM
glull's Avatar
As I understand it, the fan comes on to exhaust humidity from the cabin after the vehicle has been turned off...designed to reduce moisture issues in the ventilation systems. I believe that it comes on about 45 minutes after turning the vehicle off and stays on for only about 5 minutes or less. I assume that it is triggered by some sort of humidity sensor located in the climate control area (not 100% sure on this fact, but since it does not always trigger to come on, there would have to be some sort of triggering mechanism).
Old Nov 18, 2008 | 02:05 PM
mischief4l's Avatar
Thats good to hear. There was one hot day I came to the car and the blower was on already. It wasnt blowing cooling air like AC, just the fan was on. I was like, "K.I.T.T.???"
Old Mar 29, 2009 | 09:04 PM
vmv's Avatar
vmv
Was anybody able to solve this problem? The passenger cabin blower on my 850 GLT 1995 also turns on by itself intermittently even when the engine is off. It has drained my battery twice. Can this feature be switched off permanently.
Old Apr 1, 2009 | 10:09 PM
poor_red_neck's Avatar
I dont know about the 850 but in the S80 it is a "feature."
Its actual intended purpose as stated above is to remove condensation from the A/C condensor (or dryer I get the two mixed up)
Its supposed to only come on when you have been running the A/C (or defrost, anytime the A/C compressor has run)
Iggyomega
Apr 10, 2020 07:23 AM
nyc1836
Aug 7, 2015 11:09 AM
nyc1836
Jul 22, 2015 09:59 PM
Stb7
Nov 6, 2013 09:12 AM
