Fault Codes
Old Sep 14, 2005 | 10:52 AM
aeabston's Avatar
Default Fault Codes
Hello, I have a really bad sputter or miss when I'm sitting at a stop light and then when I begin to accelerate it's not getting full power and then it will kick in this continues up to about 50-60 mph. I took it to the dealer and they said to start with the plugs. I had the spark plugs changed there has been no change. They gave me a print out of the codes. I was wondering if anyone knew what they were or if they knew what this could be. ECM-4338, 644A, 3502, 3522, 6440, 3503, 3523, They said they checked COMP and it was ok....
Thank you
Amie
Old Sep 14, 2005 | 04:48 PM
nfinity22's Avatar
Default RE: Fault Codes
I just had the ECM replaced on my '99 S80, I had similar symptoms that you describe. For 1999-2001 models, this has been a huge problem. Check out web site: www.fazmiclaw.com/Volvo.html. They are a law firm in California trying to get Volvo to replaced these items at Volvo's expense, or reimburse owners who have had this done and paid for it already.
Old Sep 14, 2005 | 08:48 PM
ORIGINAL: aeabston
Thank you
Amie
Does it say anything next to the codes they gave you?
Sounds like maybe a throttle body issue but could also be a bad coil/coils.
Old Sep 28, 2005 | 09:43 AM
fethi icel's Avatar
The problem described is quite similiar to mine that I just wrote here today to seek advise. But in my case, the service, named the problem as transmission problem as the "transmission valve body" has to be changed.
ct60flyer
Sep 15, 2023 06:41 AM
v1lcins
May 20, 2022 10:53 AM
bkdunn
Nov 17, 2007 05:22 AM
oldbug
Mar 3, 2007 12:28 AM
uncle
Nov 9, 2006 08:45 PM
