Flashing Check Engine
Old Dec 28, 2008 | 06:30 PM
Hamzel's Avatar
Default Flashing Check Engine
I was driving my S80 today and all of a sudden the motor started to shutter as I accelerated and the check engine light started flashing?
Old Dec 28, 2008 | 06:56 PM
Hamzel's Avatar
Default RE: Flashing Check Engine
Old Dec 28, 2008 | 07:25 PM
Flashing Check engine light means it is misfiring.
Old Dec 28, 2008 | 08:15 PM
Hamzel's Avatar
How would I come about fixing this issue?
Old Dec 28, 2008 | 09:17 PM
Hamzel's Avatar
Default Climate Control
The heating and AC is not functioning at all. I've checked the fuses and there good. What could be causing this?
Old Dec 28, 2008 | 10:14 PM
Default RE: Climate Control
Either the spark plugs or coils could be bad you would need to have the codes pulled.
Any lights on the climate module work?
Old Dec 29, 2008 | 05:38 PM
Hamzel's Avatar
Current is going to the dash board but I'm guessing that there is something burned out on it cause the lights are not illuminating so im going to replace the whole climate control counsel. I found out the the hiccup on the motor was the spark plugs. Thanks for all the help tech
Old Dec 29, 2008 | 06:11 PM
glad it is coming together now!!
Old Feb 16, 2011 | 05:17 PM
1sttimevolvo's Avatar
My s80 did the same thing. I can smell rubber burning. The heat is working. If it is the heater coil. Any idea on a ball park figure to fix it? Am i ok to drive like this?
Old Feb 17, 2011 | 04:47 PM
Volvos rock's Avatar
Exclamation flashing check engine lights
The Ford/Chevy mechanic at wor has us shut the units off and have them towed if the light is flashing, states that damage is being done. They just had to replace the motor in one of the 09 Tahoes, due to someone not listening and driving it with a flashing light/miss...
Nathan007
Oct 2, 2014 06:32 PM
RRTEC
Dec 31, 2008 08:57 AM
ErnstlS90
Oct 23, 2008 08:37 AM
BRB
Feb 9, 2008 12:29 AM
Wifeys1998XC70
Sep 21, 2007 06:08 PM
