fog lights??
Old May 23, 2008 | 12:28 AM
yu21's Avatar
Default fog lights??
has anyone tried putting on a pair of aftermarket fog lights on the first generation s80??
I heard that it is not as easy as it sounds....
Old May 23, 2008 | 05:58 PM
Default RE: fog lights??
If you want to use the factory switch you will need software downloaded into the car.
Old May 25, 2008 | 03:05 AM
yu21's Avatar
dang sounds like its pretty complicated....
what if i decided to use the switch provided with the kit?? would i still need to download the software??
Old May 25, 2008 | 06:21 AM
Aftermarket switch?
Oem wiring?
If so then no but you would still have to figure the wires out from the back of the headlight switch.
Old May 27, 2008 | 12:04 PM
air force rascal's Avatar
Couldn't you just use a common ground and put a toggle switch hooked up to the battery direct..from an auto parts store on the dash somewhere..?
Old May 27, 2008 | 06:39 PM
Yes it can be done that way.
Old May 30, 2008 | 12:15 AM
yu21's Avatar
oh maybe ill try that way
thank you so much guys
rspi
Jan 13, 2012 09:35 PM
SpaceMomMort
Nov 6, 2008 02:02 AM
Volvaman
Jun 26, 2008 04:16 AM
jc740T
Nov 23, 2004 10:48 PM
